problems starting 2004 eclipse
Old Jun 21, 2007 | 10:16 PM
jwillia2000's Avatar
Default problems starting 2004 eclipse
my daughter let her car run out of gas. now won't start. any one had this issue before?
Old Jun 21, 2007 | 10:25 PM
Default RE: problems starting 2004 eclipse
The fuel pump is ceased. When pumps run dry.. thats what happens.
Lesson learned : )
Old Jun 21, 2007 | 10:34 PM
Just to make sure... have someone put their ear to the gas tank.. (or close) when turning the key to the on position. You should hear the fuel pump prime. It should sound like a high pitched hum and only for about a second.
Old Jun 21, 2007 | 10:56 PM
does tthat mean ceased as in deceased? Is this big money?
Old Jun 21, 2007 | 11:01 PM
No fuel pumps are pretty cheap. The cost is going to come from having a dealer do it.
Ceased = locked up..... so yes its dead lol
But do what i mentioned up there just to make sure ^^^
Old Jun 24, 2007 | 08:15 AM
Manybrews's Avatar
fuel pumps do not fail if you run out of gas. thats an ancient myth.
sounds like you probably dont have enough gas in the tank.
Old Jun 24, 2007 | 04:16 PM
Manybrews i have to dissagree on this one. Fuel pumps to cease when they run dry for too long... and the more reserve it has in the lines then the more it will be running dry.
Jmwatson14
Jan 13, 2016 06:14 PM
jp2000
Jan 1, 2012 05:21 PM
jwillia2000
Jun 25, 2007 07:28 PM
cagiestbat
Nov 14, 2005 05:13 PM
Parker
Sep 23, 2003 01:27 PM
