replacing 340a motor with ???
Old Dec 15, 2006 | 05:01 PM
59desoto's Avatar
Default replacing 340a motor with ???
i'm trying to help my brother so here goes. his son got water in the engine of his eclipse and says it won't crank, he says the oil is fine so i figure he bent a rod with wayer in the cyl. he wants to replace the engine it a 340a. will a neon 340a work with the eclipse head fit? the car has auto trans. will a 2.4 out of a caravan fit with the eclipse head? how hard is it to pull there engines to do this? thanks for the help in advance
Old Dec 18, 2006 | 12:08 PM
Default RE: replacing 340a motor with ???
Well just do you know, you have a 420a engine in that eclipse
Old Dec 18, 2006 | 09:54 PM
shreff99's Avatar
wow, if you don't even know the correct engine that's in it then maybe you should have someone else doing the job..I think by what you're saying that your enging would be the 420A which is non-turbo.
jjmee27
Aug 25, 2011 09:14 AM
monteroshopper
Oct 15, 2008 12:37 AM
Ralliart3000
May 21, 2008 07:13 PM
mitsubu
Oct 3, 2005 08:36 AM
