Sagging door
Can you tell me if this door part is likely to be causing my driver's side door to be sagging? The mounts on the tip hinge might be a tiny bit loose, but the crack in this also makes me wonder. It doesn't seem to be that much of a weight bearing point but....??? And what would you call this?? I have searched near and far and don't even get a lot of results searching for just 'door parts', 'door hinge', or other reasonable facsimiles.
Thanks
Thanks
crazycar2000
Oct 17, 2010 04:56 AM
MrJayDeeOne
Sep 17, 2010 04:16 AM
