Sagging door
Old Sep 20, 2009 | 01:34 PM
djailer's Avatar
Arrow Sagging door
Can you tell me if this door part is likely to be causing my driver's side door to be sagging? The mounts on the tip hinge might be a tiny bit loose, but the crack in this also makes me wonder. It doesn't seem to be that much of a weight bearing point but....??? And what would you call this?? I have searched near and far and don't even get a lot of results searching for just 'door parts', 'door hinge', or other reasonable facsimiles.
Thanks
Old Oct 10, 2009 | 12:46 AM
D.Cycle's Avatar
Default Sagging door
Is that supposed to be some kind of mist on the other side of the door? Cant say that this does scary for me. Maybe less light on this side of the door and a bit more detail in the mist.
Old Oct 10, 2009 | 01:59 PM
djailer's Avatar
??? I am talking about the part right in the center with the pin going down through it. Are you sure you got the photo to open OK? I don't see any mist??
Old Oct 16, 2009 | 08:38 AM
MacGruber's Avatar
That is the door check, and no, it's not supposed to be cracked. A sagging door typically means the door hinge bushings are worn. This is what is causing your sagging problem. The picture illustrates what I mean.
Len
May 9, 2011 01:48 PM
crazycar2000
Oct 17, 2010 04:56 AM
blackspeed
Aug 27, 2007 12:01 PM
rocky2024
Oct 21, 2006 04:17 PM
