squeeling brakes
Old Dec 31, 2005 | 05:26 AM
Luckyanu's Avatar
Default squeeling brakes
does anyone know how to stop the squeeling brakes on a 03 galant?
Old Dec 31, 2005 | 10:56 AM
Sanguinius's Avatar
Default RE: squeeling brakes
First thing are they new brakes? If they are there is a break in period for brake pads. If it's THAT bad then you might put some valve grind compound on the pad but make sure you clean the pads after a few days of driving (An inspection station here in VA failed a car I worked on because they though valve grind was grease IDIOTS...).
Old Dec 31, 2005 | 02:20 PM
jssmith6's Avatar
luckyanu,
I don't know what kind of 'squeal' you're experiencing. If you have new pads, perhaps Sanguinius' suggestion will help. If they're not new pads, consider this:
Since the mid-90's, just about every OEM and aftermarket manufacturer of brake pads puts a long flat metal tab on either the inner or outer pad that points toward the rotor. When the pad is almost worn down to the metal, this metal tab is designed to rub against the rotor and cause a loud ringing sound. This is to warn you that if you don't replace the pads soon, that you'll be grinding into your rotors.
Only a visual inspection of the noisy brake will confirm this condition.
Old Jan 15, 2006 | 01:22 PM
wicked_outlander's Avatar
change your pads....it squeeling because the indicators probly touchin the rotor surface.
msport_2_outlander
Jan 9, 2015 07:30 AM
XBMRX
Jun 15, 2007 11:15 PM
DaShot19
Feb 23, 2005 12:28 AM
99eclipseguy
Oct 29, 2004 03:37 AM
rollin_hard
Oct 29, 2003 03:52 PM
