Stuck (and now broken) brake bleeder valve screws.
Old Dec 13, 2021 | 02:59 PM
Apollo11's Avatar
Default Stuck (and now broken) brake bleeder valve screws.
Im trying to bleed my brakes, the very first bleeder valve broke off almost instantly. Ive been working non-stop with a torch, deep creep and ez out sets, heat cycling, hammering, etc. and nothing is coaxing it out, it's flat out welded in place. So I'll have to replace this caliper as my last ez out bit broke off inside the bleeder. Only 3 others to go! Idk if I'll end up with new calipers all around or if someone can help with some workable fix for this that i can try.
Idk what it is with Mitsubishis, but it seems like they use the wrong metals in the wrong places, I've run into countless frozen bolts and screws and more than half of them break right of the bat.
Im hoping someone has some advice that actually helps. Everything I've tried from online videos has done nothing to help.
Radikal
Aug 13, 2020 09:54 AM
calinights420
Apr 10, 2020 08:00 PM
yasuji514
Feb 23, 2012 03:15 PM
ryan6458
Nov 18, 2010 09:53 PM
TheEngineer
May 29, 2008 08:28 PM
