Are there problems with my new transmission?
Old May 22, 2012 | 03:09 PM
gthornwell's Avatar
Angry Are there problems with my new transmission?
Hi,
In December 2011, I paid over $4800 for a re-built transmission on my 2011 Montero Sport - specifically, I paid for the following:
  • 6 Spark Plugs
  • Ignition WiresPlugs
  • Timing BeltFan & Alt
  • Timing Belt Tensioner Component Kit
  • Camshaft Tensioner
  • Idler Pullies Pulley
  • Upper Radiator Hose P/S Belt
  • Lower Radiator Hose PCV Valve
  • Serpentine Belt A/C Belt
  • Valve Cover Gasket
  • Battery Intake Gasket Set
  • 13.6 Labor
  • Exchange Transmission LKQ - Lifetime Warranty
  • 7.5 R&R Transmission LKQ
  • Special Discount Curved Rad Hoses
The problem(s):
1) The "A/T Temp" light comes on when I am driving more than 60 mph for more than 30 minutes
2) The four-wheel drive light comes on - no specific speed limit or no specific drive time - the light just comes on at will.
Question(s):
1) Are these two "problems" related?
2) Did the mechanic complete the job inaccurately or incompletely?
Thank you,
gthornwell
Old May 22, 2012 | 11:03 PM
mxmikie's Avatar
what did the shop that did the job say when you took it back to them with these problems ??????
Old May 23, 2012 | 09:24 AM
gthornwell's Avatar
Well, I haven't taken the truck back to the transmission mechanic as yet, instead, because I don't trust the transmission mechanic, I took the truck to a local Mitsubishi service center - described the problem and here's what the guy at the garge front desk told me:
1) Regarding the A/T Temp Light: The A/T Temp light is coming on b/c the transmission fuel is heating up and that the truck will need a larger tray - will cost you close to $1,000 to replace the tray.
2) Regarding the four-wheel drive light: The Four Wheel drive light is a separate issue - unrelated to the transmission. (He never gave me a reason "why" the four-wheel drive light is coming on however).
Old May 23, 2012 | 02:34 PM
mxmikie's Avatar
the dealer sounds like a idiot take it back to the shop that did the job
jp2000
Jan 1, 2012 05:21 PM
94 Mitsu Eclipse
Dec 20, 2010 06:59 PM
superinflamo
May 19, 2006 03:01 AM
snake240
May 3, 2006 03:34 PM
administrator
Apr 17, 2004 04:38 AM
