Tranny problems
Old Aug 25, 2006 | 05:48 PM
xslim69's Avatar
Default Tranny problems
i have a 97 gst i have no 3rd or 4th gear, but i have 1st,2nd,5th and reverse. doen anyone know what the problem is
Old Aug 25, 2006 | 09:11 PM
VR4GARY's Avatar
Default RE: Tranny problems
Sounds like your linkage has a problem. Check under the hood, drivers side firewall. Make sure that all of the linkage is in place. Could be just a loose connection.
Old Aug 26, 2006 | 12:09 AM
xslim69's Avatar
i have done that and every thing was ok. could it be an internol problem
Old Aug 27, 2006 | 12:10 AM
Blythetrynity's Avatar
can you get into gear at all even with the car shut off?
If you can't it very possibly could be your tranny gears or bearings... mine cost $85 for an 01 and I did it myself with a press in a day ( keep in mind I'm a girl and not as fast as some of you guys out there)
If you can with the engine shut off but not on check your clutch..... highly unlikely though because you can get into your other gears.....
so I would bet more on tranny
Old Aug 27, 2006 | 02:11 AM
Try bleeding the clutch and flushing out all the old fluid replacing it with new.
How is your clutch? How many miles are on the clutch? Do you drive hard? Powershift?
Old Aug 28, 2006 | 10:20 AM
i really cant see this being a clutch problem since you do get 3 out of 5 gears. I would say a linkage since the two you dont get happen to be right in the center. Did you check the throw under the console?
Old Aug 28, 2006 | 09:29 PM
xslim69's Avatar
Yes the linkages are hooked up right, and the throw under the console is good. Is their a way to adjust the linkages? But i dont think that it is a linkage problem.
Old Aug 29, 2006 | 09:40 AM
I dot think there is anything that adjusts linkages. Maybe it just is coincidence that its the center ones but it could just be the tranny. Maybe bad syncro's. Have you tried with the car off yet like blythetrynity suggested?
Old Sep 7, 2006 | 05:19 PM
xslim69's Avatar
found problem pulled the trand apart and found that the shift fork broke for thoes 2 gears.
Old Sep 7, 2006 | 09:00 PM
Well at least you found what was wrong. Thanks for lettin us know.
jp2000
Jan 1, 2012 05:21 PM
TransAmist
Mar 15, 2006 06:47 PM
1997gsteclipse
Nov 28, 2005 07:39 PM
venom3230
Jan 12, 2004 08:32 PM
ikon_01
Sep 8, 2003 01:03 AM
