Transmission flare
Old Aug 16, 2005 | 05:21 AM
jeremy's Avatar
Default Transmission flare
I am from Malaysia. I drive a local Proton (similar to a Lancer) fitted with a 1.6L Mitsubishi 4G18 engine with F4A41 auto gearbox with INVECS-II. Problem is that of late, I am having shift flares (engine rpm rises between shifts) when it changes from 1-2 and 2-3. It doesn't happen alll the time but quite often and is very irritating.
I have tried resetting the ECU by disconnecting the battery and also flush the ATF and refilled with SP-III oil, but it still happens though a bit better.
Any suggestions other than to change the gearbox?
srinath
Apr 19, 2014 09:23 AM
DMCGEE
Jul 11, 2011 09:24 AM
deturner
Sep 12, 2007 06:39 AM
ern
Jan 31, 2007 08:59 AM
xenomorff
Feb 17, 2006 01:20 AM
