vehicle will not stay running
Old Aug 26, 2005 | 12:40 AM
freetime17's Avatar
Default vehicle will not stay running
I just change the alternator on my 3000gt and now it will not stay running at idle. also do you know a way for me to get the code to turn my music back on.
Old Aug 26, 2005 | 01:02 PM
Patrick's Avatar
Administrator
Default RE: vehicle will not stay running
if you contact a dealership with the VIN, they may be able to help you...i was unaware that 3kgt had a security radio code??
did you touch anything other than the alternator? have you tried hooking a battery charger to it, and seeing if that helps?
why did you change the alternator? are you sure that it was bad?
Old Aug 26, 2005 | 01:54 PM
freetime17's Avatar
yes the alternator was shot i took my lady to a shop and had it tested, also someone at advance auto told me i had to keep it running for five minutes at 2000 rpm in order for the computer to reset. never heard that befor any ideals
Old Aug 26, 2005 | 03:58 PM
DSMTalonAWD51's Avatar
ive never heard of the 2k rpm thing. after you reset the ecu its a good idea to let it sit and idle for 5 minutes or so, but if its not able to idle on its own you probably have a vacuum/intake leak and id look around.
Old Aug 26, 2005 | 04:25 PM
Patrick's Avatar
Administrator
yes...do you hear any "sucking" noises anywhere under the hood??
trailer trash
Apr 21, 2009 10:37 PM
henry75
Aug 24, 2006 03:45 PM
henry75
Aug 23, 2006 11:01 PM
bigrob069
Jul 16, 2004 09:06 PM
cooley
Apr 1, 2004 01:59 AM
