Vibration
Old Feb 5, 2005 | 11:03 PM
2step's Avatar
Default Vibration
OK changed the timing belt and now have a bad vibration over 4000 RPMs, some one said the oil pump or silent shafts were out of time, how do you do that? All the timing marks are lined up. Wheres the plug you are to take out and check to see if everything is in line. Thanks '92 Eclipse GSX AWD 2.0 Turbo
Old Feb 8, 2005 | 01:53 PM
1398spdr's Avatar
Default RE: Vibration
id check the balance shaft pully, make sure its not about to go..............
Old Feb 8, 2005 | 09:57 PM
SpyderGS's Avatar
1398's got it. It's most likely the balance shafts. Kind of a rule among the community, always check the balance shafts when doing a T-belt job. Most people just delete them all together, but it's a matter of opinion on whether it's good or not. There are kits available to remove the balance shafts from places like RRE or Buschur Racing, and they're under $50.
RaiderNick
Feb 21, 2006 01:11 PM
00GalantMan
Jan 29, 2006 01:08 PM
wulls1313
Aug 21, 2005 12:54 PM
95EclipGS
Aug 9, 2005 09:24 PM
Davet2
Oct 18, 2004 01:39 PM
