Vibration while braking
Old Aug 7, 2005 | 04:28 PM
95EclipGS's Avatar
Default Vibration while braking
i just got a used 95 eclipse GS 2 weeks ago and there is vibration when i am braking. the steering wheel vibrates too, could this just be that i need to resurface my rotors or do i need new pads? id appreciate any help anyone can give me
Old Aug 7, 2005 | 06:49 PM
DSMTalonAWD51's Avatar
Default RE: Vibration while braking
get the rotors resurfaced most likely
Old Aug 7, 2005 | 11:15 PM
97redEclipse0010's Avatar
Wow, I thought I was the only one who had that problem. I also had it mentioned to me that it might be a caliper thats sticking. I don't know if that's true or not but I'm having the same vibration problems at any rate. I don't know if it's true for you but after a casual afternoon of driving you'd think I'd been on a road track for hours from the temp of my brakes so yeah...theres my input.
Old Aug 8, 2005 | 04:44 PM
wicked_outlander's Avatar
resurface your rotors and replace pads.....
Old Aug 9, 2005 | 01:49 AM
slow420a's Avatar
Someone did a cool 120 to 0 brake a few times... or at least thats how I warped/cracked my rotors.
Old Aug 9, 2005 | 04:31 AM
JayR's Avatar
I had that my on my old 01 eclipse rs and i changed my rotors and pads and it was perfectly fine after that, rotors dont cost that much so i would suggest replacing them instead of resofacing them, thats my advice...
Old Aug 9, 2005 | 11:36 AM
ORIGINAL: JayR
there you go....best thing and safer ....replace your rotors, and i think rotors run for about $45 buckz?? er' up...but its cheap for a set.
Old Aug 9, 2005 | 12:14 PM
95EclipGS's Avatar
i found rotors for $40 a piece so i may as well replace them and the pads. thanks for the advice!
Old Aug 9, 2005 | 09:24 PM
cocosun's Avatar
I had this same trouble with my 2003 GS. I was told the rotors are quite thin on these cars and warp easily. My rotors were resurfaced twice and then finally had to be replaced a year or so later. Best of luck!
demoon80
Oct 10, 2021 01:23 PM
jimmy42010
Nov 2, 2011 10:02 PM
BrokeDad
May 15, 2009 07:16 PM
seeleyjon
Feb 6, 2009 07:11 AM
glttrybuttrfly
Aug 18, 2005 11:18 AM
