weird rubbing noise
Old Sep 18, 2006 | 05:31 PM
piotrekmile's Avatar
Default weird rubbing noise
hey guys i was wondering if u can help me out... i have an 04 lancer es and im gettin some kind of weird rubber on rubber rubbing and squeaking from under my car and when i turn to the right at higher speeds i hear a thumping and feel like weird pulsations.... thanx for any input
Old Sep 19, 2006 | 09:37 AM
Default RE: weird rubbing noise
is the vibrations only when you turn one way? Do you feel the vibrations when your stopping or any indication that it could be from your brakes?
Old Sep 19, 2006 | 05:03 PM
when im going straight its very slight vibrations but the thing is when im on my brakes it stops kinda
Old Sep 19, 2006 | 07:44 PM
vibrations through your steering wheel?
Old Sep 19, 2006 | 11:00 PM
not really through the stearing wheel, but i can feel them..... like throught the car
Old Sep 19, 2006 | 11:33 PM
dwork2160's Avatar
sounds like a loose axle nut or maybe even a strut bolt loose
jack the front end off the ground and see if either wheel is loose
Old Sep 20, 2006 | 07:33 PM
tuss2oo5's Avatar
I had that problem once, check your sway bar. mine was broke and did the thigs you described in my galant.
Old Sep 21, 2006 | 11:34 AM
i dont think youd really get vibrations though from a sway bar. I only really got a banging sound when mine went
Old Sep 21, 2006 | 07:18 PM
could be a wheel bearing? Warped rotor? Bad break pad sitting? Pads need changing???
SERPENTOR
Jun 11, 2014 04:08 AM
bhanot
Jan 15, 2014 11:41 PM
Dommy93jars
Jan 5, 2012 01:12 AM
agallardo
May 24, 2006 10:34 PM
kb0282
May 2, 2005 08:07 PM
