whats an idler pully, what does it affect on 3000gt
Old Jul 16, 2005 | 12:09 AM
enzo_hashmat2006's Avatar
Default whats an idler pully, what does it affect on 3000gt
my car idles alot and i heard that there was an idler pully that i could replace. will it help reduce the problem or is it a was of time
Old Jul 16, 2005 | 07:08 AM
antomx's Avatar
Default RE: whats an idler pully, what does it affect on 3000gt
I assume by your saying your car idles alot, you mean it idles high. A new idler pully would'nt help in such a case. Its main job is to guide and keep tension on your belt. It's probably your idle sensor or a vacuum problem (vacuum hose loose ect.) It could be due to other problems but those are the 1st things I would check.
Old Jul 18, 2005 | 02:36 AM
It doesn't idle on the RPM, but on the MPH scale. i thought it was the injectors, but it wasn't.
Old Jul 20, 2005 | 07:48 AM
JDMVR43000's Avatar
Wait so you are idleing on the MPH(wont rev i'm assuming) most likely vacuum leak like the other guy said.
Old Aug 8, 2005 | 06:16 AM
turbobird14's Avatar
ORIGINAL: enzo_hashmat2006
HAHA definatley a newbie question...thats ok though...search around and there are tons of posts about that
col_dan
Feb 26, 2014 06:40 PM
timidater
Apr 25, 2013 03:17 PM
klimbo
Feb 1, 2011 09:21 AM
enzo_hashmat2006
Oct 3, 2005 02:18 AM
spyder-man
May 24, 2004 05:26 PM
