Will different tire affect the AWD system?
Old Feb 26, 2014 | 12:37 PM
col_dan's Avatar
Default Will different tire affect the AWD system?
Hey Guys,
I own a 2008 Outlander XLS AWD that has Yokohama Avid TRZ tires on it. Yesterday I screwed one of the tires up and went out to discount tire this morning to get a replacement. Just my luck, Yokohama have discontinued that tire, but they had Yokohama YK580's in stock, same size 225/55/R18, but the guy working there is recommending that I get four new tires as putting one different one (albeit the same brand and size) on he says will over time screw up the transfer case.
That seems unlikely to me, but can anyone on here with greater knowledge that I comment?
If it is the case, can anyone comment if that tire would be decent in snow? I live in Denver and head up to the mountains for skiing once in a while and I have been the TRZ's pretty bad in snow. Any other recommendations?
Thanks
Dan
Old Feb 26, 2014 | 01:25 PM
ccernst's Avatar
Depending on how much wear you have on your remaining tires would be a factor in the number of tires bought. Our AWD system is not completely standard.
Traditional 4x4, like my Ranger, uses a transfer case to split power 50/50 to front back, with no room for differences in tire size. You cannot use it on pavement or where you have a lot of traction.
Some vehicles, like the Jeep Liberty, uses a third differential to split the power front to back. The spider gear would allow for limited pavement use, since the differential would compensate for different tire sizes.
Our Outlander uses an electronic clutch pack just in front of the rear differential that controls how much power is sent to the rear wheels: none, 20-40% (auto), 50-60% (lock). Since power output is adjustable, I'd think it'd be acceptable to run a mix of new/used. However, I'd strongly suggest purchasing in pairs rather than just one. I'd also put the new ones on the front and stick with 2WD mode for a while until they wear down to approximately the same size.
Old Feb 26, 2014 | 02:05 PM
col_dan's Avatar
Thanks very much; I've been sitting here wondering if buying two new ones would be acceptable. Would certainly be more acceptable to my pocket book
Old Feb 26, 2014 | 02:09 PM
ccernst's Avatar
yeah, safest bet is to put them on the front and wear them down to the same size.
Edit: would give you an excuse to turn ASC off and punch it! "...just gotta get them worn down to the correct size, dear."
Old Feb 26, 2014 | 06:40 PM
Akzle's Avatar
tyres should never be replaced singularly. At least a pair.
Brian Yazzie
Jan 23, 2012 09:27 AM
samwoo2go
Mar 26, 2010 06:17 PM
enzo_hashmat2006
Oct 3, 2005 02:18 AM
enzo_hashmat2006
Aug 8, 2005 06:16 AM
