whys it squieal on start up?
Old Aug 13, 2007 | 08:27 PM
5star's Avatar
Default whys it squieal on start up?
When I start my eclips now it always makes a squieal sound for a few secs. Whats making it do that?
Old Aug 13, 2007 | 08:54 PM
Dusty Eclipse's Avatar
Default RE: whys it squieal on start up?
About a 90% chance that its your belts. Try spraying some belt dressing on all the belts but your T-belt.
Old Aug 14, 2007 | 03:48 AM
silvercoupe97's Avatar
Another way to narrow down the belts is to leave the a/c off during the initial start. If it still squeals, then it's the power steering belt, if not, then it's the a/c compressor belt. Those are the common ones. Your timing belt should not be squealing at all since it is kept in sync with the cams and crank by toothed gears.
Old Aug 16, 2007 | 05:20 AM
ComposeEvo's Avatar
spray wd40 ont he belts
lol i'm just kidding. Dont ever do that.
It's most likely a belt that is just old and wines until it heats up and relaxes. Replace the belts, and tension them well.
Gus
Old Aug 16, 2007 | 11:40 AM
Lil Evo's Avatar
^^^wut he said. general maintenance is all it is my friend, general maintenance
Old Aug 24, 2007 | 07:13 PM
kmauger07's Avatar
i had this happen to me and i sprayed belt dressing on my belts except the timing belt and it would stop for minutes then start again...then it kept throwing them off..most likely,because this is what was wrong with mine,either you have a belt on crooked,,just a groove over from one pulley to the next or your balancer is off..my balancer was broken so i had to spend 120 bucks to get a new one from jegs..you can find them cheaper though..i just took the quick way out..
[/align]
Old Aug 24, 2007 | 08:05 PM
I spray the freakin things with WD-40 and 3 years later htey are fine and they dont squeel... DO IT
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
