1.8l wiring harness on 2.0 motor
Old Nov 8, 2006 | 07:48 PM
royb04's Avatar
Default 1.8l wiring harness on 2.0 motor
CAN ANYONE HELP ME? I am wiring a 4g63 with a 1.8 liter wiring harness. Any advise. (cant aford 300-500 harness) and cant find one if i could. I have used alldata, hanes, and chiltons wiring diagrams but there is some things missing. Like the inputs on the 1.8l mpfi reley. Where do i run the 3rd wire (red) on the crank/cam angle sensor on that reley. Is it input or out put to the mpfi relay. I cant get any spark. and the fuel pump wont turn on. I have the 4g ecu hooked up and pins have been move for fuel pump and wires ran for coil. am i missing something. I might just run a switch to the fuel pump if i can get spark.
And i also need a oil pan for a 4g63.
If anyone has a harness for cheep i need one of those too.
Old Nov 8, 2006 | 08:24 PM
Sanguinius's Avatar
Default RE: 1.8l wiring harness on 2.0 motor
Dude why in god's green earth are you reinventing the wheel???
Go to a local junkyard/pick'n'pull and you can pick up a wiring harness for MUCH less than $100 I'm sure. You may have to go through the trouble of pulling it yourself but it will save TONS of trouble in the long run if you ask me.
Pokerdude
Oct 1, 2006 07:51 PM
Mac_attack769
Sep 6, 2006 04:41 PM
AllThingsDSM
Feb 8, 2006 01:33 PM
Reddragon06
Jan 24, 2006 01:43 PM
denied
Feb 9, 2005 12:16 AM
