1990 2.0 cold start problem
Old Jan 25, 2009 | 03:22 PM
1990gs2.0's Avatar
Default 1990 2.0 cold start problem
Ihave a 1990 EclipseGS 2.0 that has developed a cold start issue. It began 6 weeks ago after I replaced a starter. When cold it turns over fineand start to catch but willnot run. When it does finally start running it will only idle - if I step on the throttle it will die. After it warms up it is ok. I can heat the throttle body up and it starts fine. This only is happening when the temp drops below40degrees and the car sits several hours....overnight or at work 8 hours. When the air temp is back above 40 degrees it will start fine. It has no problem running when warm.I checked for vacuum linesall seems intact. No previous problem over last 2 years. Any ideas ?
Old Jan 25, 2009 | 07:58 PM
dsm1990gsx's Avatar
Default RE: 1990 2.0 cold start problem
No need to double post, check the 1g eclipse section.
rob.allee
Jul 14, 2014 04:35 PM
buffvail
20
Mar 25, 2014 07:00 PM
mysticrythms
Mar 19, 2014 08:17 PM
1990gs2.0
1st Generation
Jan 27, 2009 11:52 AM
hanna.karr
Jan 10, 2009 03:22 AM
