2009 Mitsubishi Lancer NO POWER TO FUEL PUMP
Old Apr 2, 2024 | 09:27 PM
luiscamacho06's Avatar
Default 2009 Mitsubishi Lancer NO POWER TO FUEL PUMP
HEY EVERYONE,
I have an 09 Lancer ES. Im getting no power to the fuel pump. Car cranks just fine with no start. I sprayed a little Ether in the intake and fires righht up so i know its a fuel issue.
I inspected the fuel pump wires and stuck a tester and noticed im getting no power to the pump in any of the plugs. one plus had very low power. tester barely lit up.
I also scanned car and got a code for camshaft sensor. i do not believe the camshaft sensor would cause no signal or power to fuel pump.
im stumped
Old Apr 3, 2024 | 03:02 AM
DibbyDibbyDJ's Avatar
If the ECU does not see the signals from the cam and crank sensors it does not know the engine is spinning. Therefore it will not allow fuel pump and ignition to run
mitsnewbie68
Aug 30, 2012 03:07 AM
smokeyred_dot
4th Generation
Sep 21, 2011 03:44 PM
kelrayment
Jan 15, 2011 08:01 PM
shiguy
Oct 6, 2008 12:14 PM
foetus envy
Jun 24, 2008 05:53 PM
