95 mitsubishi eclipse gs
Old May 13, 2008 | 12:17 PM
tex1994's Avatar
Default 95 mitsubishi eclipse gs
hey guys...... need some help please ok yesterday i went out to my car and tried to start it up and it hesitated but it did well it started idleing kind of weird well i figured i would get it out on the road and when i started to go it did fine but when i got to 3500 rpm's it started to stall and it does it in every gear its like it set the rev limiter to 3500 and this is a 95 mitsubishi eclipse gs if anyone can help me out i would really appreciate it if you have any questions just ask and i will try to get the answer as soon as possible thanks
Old May 13, 2008 | 02:33 PM
dsm1990gsx's Avatar
Default RE: 95 mitsubishi eclipse gs
Replace your plugs and wires.
Old May 27, 2008 | 05:33 PM
tex1994's Avatar
hey guys ok i changed my plugs and wires but the car is still running like crap i have done the key dance and it gives me a bunch of different codes here and there like sometimes it will only be 24 and then it will be 24 and 22 and then it will be 24 22 23 14 and i have replaced the throttle position sensor because thats the main one that keeps popping up but it didn't help but all the codes come back to maybe being that my 5 volt supply output is to low or to high so what can i do about that please let me know thanks
Old May 28, 2008 | 01:19 AM
tex1994's Avatar
come on guys does any one have a clue i really need some help please help me
Old Jun 4, 2008 | 09:13 PM
tex1994's Avatar
well anyways thanks for the help guys i figured out whats wrong it was the ecu
Old Sep 5, 2008 | 09:48 AM
c3o5nnect's Avatar
Sounds like you should check your spark plugs and wires, if that doesnt work you may have an issue with your distributor.
DigitalEclipse
Nov 26, 2011 05:51 AM
miikka
Apr 5, 2010 09:24 AM
XIOZZYIX
Nov 18, 2009 09:04 AM
FAX68
Feb 6, 2009 12:41 PM
venum
Aug 3, 2005 11:58 AM
