any problems!
Old Aug 23, 2006 | 10:11 PM
bud660r's Avatar
Default any problems!
ok i bought a 95 eclips gs. what i am woundering is, is there any problems that i should watch for. or any thing i should replace that is factory and goes out or might be out and i dont know it.
Old Aug 24, 2006 | 07:44 PM
Manybrews's Avatar
Default RE: any problems!
make sure your timing belt has been replaced if the milage is high.
Head gasket leaks (oil) are very common.
front end suspension wear is common from the lateral arms, compression arms, struts, sway bar bushings, and tie rod ends, but the lateral arms would be covered under a recall if they're worn and havent been replaced before.
Old Aug 24, 2006 | 09:24 PM
^^^ well he's basically covered it all.
Old Aug 25, 2006 | 03:33 PM
bud660r's Avatar
thanks for the help i will goe through these asap!
jp2000
Jan 1, 2012 05:21 PM
brucepa
Mar 6, 2007 11:09 PM
brucepa
Mar 6, 2007 05:41 AM
iwantmooreshawn
Oct 25, 2006 02:59 PM
D3SOLATION
Apr 5, 2005 12:03 AM
