compression
Old Dec 27, 2007 | 02:55 PM
BLAZE GS's Avatar
Default compression
so, last night i put the flywheel and trany back on my EBAY BOUGHT[sm=badidea.gif] engine and got these #'s 125 125 90 110.[sm=smiley35.gif]ok this is what i have.#2 motor with bad bottom end,#1 a motor with good bottom end but bad head,#3 7 bolt engine which the timing belt snapped. now i guess im going to swap heads and then call it good i hope.......
Old Dec 27, 2007 | 03:04 PM
kweef's Avatar
Default RE: compression
well i hope it all works out for u...but like u said, ebay bought
Old Dec 27, 2007 | 07:48 PM
dsm1990gsx's Avatar
That sucks, try doing a cylinder leak test to see where your problem is.
Old Dec 27, 2007 | 09:45 PM
BLAZE GS's Avatar
it most likely the valves because the belt was lose and i think it jumped but how would i do a leak test?
Old Dec 28, 2007 | 06:52 AM
dsm1990gsx's Avatar
Well you need a cylinder leak tester, then you have to have the piston at top dead center w/ all the valves closed and you test 1 cylinder at a time. You pull the spark plug out and insert the tool into the plug well and pretty much add compressed air and see how much leakage you have for that cylider.
Or you can just pull the head off a see if the valvesare bent lol.
Powertech
Apr 1, 2006 06:35 PM
5Tizzle
Feb 14, 2006 09:17 PM
iceman
Feb 4, 2006 12:00 AM
TheMatt06
1st Generation
Jan 29, 2006 02:42 AM
vertstanggt
Jan 9, 2005 12:13 AM
