How To Reset "Service Required" Light?
Old Mar 26, 2008 | 01:30 AM
scooter's Avatar
Default How To Reset "Service Required" Light?
I have a 1989 Mitsubishi Montero LS Sport with 6 cylinder 3.0 liter engine that just passed 200,000 miles....the "Service Required" Light has come on. How do you reset the "Service Required" light??? I have serviced the transmission, transfer box, and the complete 3.0 liter engine as fully as possible. I cannot locate the switch in the dashboard to "throw" to reset the "Service Required" light for the next 200,000 miles. I understand that this switch is somewhere behind the dashbord. Does anyone know precisely WHERE this "reset switch" is located? How do you reach it? In the meantime the "Service Required" light stays on continually! Thank you so much. Scooter[/align]
Old Mar 26, 2008 | 08:21 AM
dsm1990gsx's Avatar
Default RE: How To Reset "Service Required" Light?
That might mean you have a problem w/ the car, see if there are any codes and to reset it just dissconect the battery for 5-10 min and it should go out.
Old Mar 26, 2008 | 02:45 PM
More like 30 seconds - 1 min
Old Mar 26, 2008 | 06:13 PM
blk n tan's Avatar
that switch is behind the dash. someone just called us yesterday asking where it was
Old Mar 27, 2008 | 12:10 PM
dsm1990gsx's Avatar
ORIGINAL: Sebba
Yeah your right I was thinking abt the newer cars that have (KAM) keep alive memory.
Old Mar 31, 2008 | 09:16 PM
jgbrules's Avatar
hello! the switch your asking about is on the back side of the instrument cluster. you dont have to completely remove it to get access to the switch.pop off the top trim piece and look on the left side of the cluster, its just a little black toggle switch, very small. just simply use a pair of angle pliers or something small that is curved on the end to stick in there and simply move it up or down. depending on what postion its in, simply move it to the opposite postion. you cant use a scanner to clear that light. battery disconnect wont work either. have to move that toggle switch!! good luck!! greg....
GPSeek
Oct 24, 2023 08:18 PM
Shanehane
Jun 14, 2018 03:02 AM
clattin
Jun 27, 2013 06:14 AM
vrxprince
Dec 10, 2011 01:49 AM
