Montero Sport 2000 XLS Timing or sensor Problem
Old Mar 11, 2013 | 06:28 PM
Kuban0's Avatar
Question Montero Sport 2000 XLS Timing or sensor Problem
Hi, I need some help, I have a 2000 Montero Sport XLS 3.0, I have to change the camshaft seal because was leaking oil, after that of course I change the tensioners, water pump and Timing Belt, before install the new parts I clean the area with Formula 88 Degreaser but I dont disconnect the sensors, after that I install back everything and when try to start, nothing happens, I take the crankshaft sensor out, I clean the sensor and after that the engine start but making noises and shaking a lot, I dont know if is sensors problem or Valves bended, I move a little the time to see if I fixe the problem and was doing the same,,,, I dont know wath to do,,,,,
Old Mar 11, 2013 | 09:55 PM
mxmikie's Avatar
sounds like the timing is out
Old Mar 11, 2013 | 11:02 PM
Kuban0's Avatar
But I need to know in first place if the valves are ok or not, how can I check that?
benjaminpadillaa
Oct 29, 2012 08:55 PM
Nastyben1
May 13, 2012 03:29 PM
3000GTrallyarts
Jul 26, 2010 06:50 PM
Ken B 76
Dec 12, 2009 12:53 PM
frohboy33
Apr 7, 2006 02:07 AM
