P0335, p0340
Hi, I have a 2002 Dodge Stratus Coupe 3.0 engine.(Dodge's version of the Eclipse I believe) I know it's made by Mitsubishi and given to Dodge that's why I'm here...I'm getting both P0335 and P0340 codes. Most recently as far as repairs to the car was a distributor, cap, and rotor replacement due to a stall that the car couldnt recover from(no start). I was told the distributor was new and not rebuilt but not the brand name of it. The car has terrible gas mileage and I hear my fuel injectors ticking/clicking(or however you want to explain it) From what I understand my engine doesn't even have a external camshaft position sensor and that it's built Inside the distributor? Could my timing belt be off? Is my timing chain/belt loose,mistimed, worn? Could the power wires be damaged or shorted out? Any help would be greatly appreciated! Thanks!!!
I want to add that I had neither of these codes, or the ticking injector noise prior to the distributor swap. It all came about after that.
Sorry if this isn't in the right section. I wasn't sure where to put it and general seemed fitting.
So the crankshaft position sensor is build into the distributor. Replacing it would mean replacing the distributor...again?
