P0335, p0340
Old Jun 7, 2014 | 10:18 PM
Matt James's Avatar
Default P0335, p0340
Hi, I have a 2002 Dodge Stratus Coupe 3.0 engine.(Dodge's version of the Eclipse I believe) I know it's made by Mitsubishi and given to Dodge that's why I'm here...I'm getting both P0335 and P0340 codes. Most recently as far as repairs to the car was a distributor, cap, and rotor replacement due to a stall that the car couldnt recover from(no start). I was told the distributor was new and not rebuilt but not the brand name of it. The car has terrible gas mileage and I hear my fuel injectors ticking/clicking(or however you want to explain it) From what I understand my engine doesn't even have a external camshaft position sensor and that it's built Inside the distributor? Could my timing belt be off? Is my timing chain/belt loose,mistimed, worn? Could the power wires be damaged or shorted out? Any help would be greatly appreciated! Thanks!!!
I want to add that I had neither of these codes, or the ticking injector noise prior to the distributor swap. It all came about after that.
Sorry if this isn't in the right section. I wasn't sure where to put it and general seemed fitting.
Old Jun 8, 2014 | 09:39 AM
Matt James's Avatar
Originally Posted by jkeaton
Yes, the CPS is built into the distributor. Obviously whoever told you it was new is lying. Those codes are specific to the CPS. Replace it.
So the crankshaft position sensor is build into the distributor. Replacing it would mean replacing the distributor...again?
slavao
Feb 2, 2012 06:55 PM
Shepard69
May 20, 2011 08:50 PM
rascosss
Oct 28, 2010 07:51 AM
05-6G72
Oct 20, 2010 08:51 PM
Rob
Jan 8, 2008 05:58 PM
