replacing parts
Old Jan 27, 2008 | 09:42 PM
BLAZE GS's Avatar
Default replacing parts
is there anything that i should replace on my 93 eclipse because im doing engine work. i know timing, water pump, clutch,halfshafts, i bought a rebulit head.....um anything else im forgetting or i need to replace?
Old Jan 28, 2008 | 06:56 AM
Default RE: replacing parts
obviosously all the valve cover gasket stuff youll need. I would probably replace the tensioner as well
Old Jan 28, 2008 | 09:46 AM
RCJr9186's Avatar
well if it's gonna be apart... timing belt, water pump, tensioner, head gasket, head bolts (arp recomended for high hp applications), idler pulley, tensioner pulley, if you wanted to, you could get some light weight pulley's while everything is apart... not a big deal but it does take a lil load off the engine. you don't have to replace the clutch unless urs is going out or you plan on maxing it out. but if you do make sure that you buy one that will withstand the hp you are planning on running. valve cover gasket, oil, trani fluid, spark plugs, wires. depends on how far you are willing to go to be honest. you could replace ur motor mounts w/ urethan for less wheel hop (but it will make the ride a lil stiffer/rougher). there are tons of things you could do, depends on the budget, plans and patience lol.
fungusboy
Dec 13, 2012 09:34 PM
turismo69
Sep 23, 2007 01:30 AM
SamGST97
Aug 31, 2007 02:52 PM
ALTEREVO
Dec 17, 2005 01:11 AM
shawnharper
Jan 31, 2005 03:30 PM
