slipping rear wheels
Old Sep 22, 2007 | 08:56 AM
mkw60677's Avatar
Default slipping rear wheels
Hi there everyone, My 1993 GTO from Japan automatic will not go round corners without the rear wheels slipping. We have changed the rear differential and transfer box to no avail. It seems as if the rear wheels are trying to move faster than the front and they jerk round when cornering. Would anybody out there like to offer advice on what the problem might be. Thanks to you all in advance.
Old Sep 22, 2007 | 02:34 PM
nick_200321's Avatar
Default RE: slipping rear wheels
well if you are used to imports, your problem is probably not realising that you not have a RWD car and it sucks at taking corners, you just more than likely are putting too much power to it and losing traction
Old Sep 22, 2007 | 02:35 PM
wait.. did you get a limited slip differential? if not i would have
Old Sep 22, 2007 | 03:49 PM
ComposeEvo's Avatar
try stickier tires in the rear, That happen to my typhoon. But i'm sure that the problem that i was having was the same as yours.
Gus
Old Oct 9, 2007 | 02:31 PM
Master Mitsubishi's Avatar
sounds to me like you have a welded vcu, helps you launch harder but does make the tires bark when you take tight turns... for dsm guys its the same as a welded center diff
Old Oct 10, 2007 | 11:34 AM
RCJr9186's Avatar
suspension mods always help w/ traction, a nice combo of shocks and struts or coilovers will give you a great deal more grip and there are DOZENS of other ways and other parts to make you get better traction.
Old Oct 11, 2007 | 11:38 AM
ORIGINAL: nick_200321
Sorry this post doesnt make any sense, first its apperant he has an JDM GTO since GM didnt make GTO's in 93 and that GTO's only came in AWD and FWD, it has to be an AWD car since he mentioned a rear diff. Also RWD cars sux at taking corners???? F1 cars are RWD,soare vettesand all the other great handling cars.
eclipsefanatic
Feb 9, 2007 09:53 AM
kaiba408
Feb 5, 2007 07:34 PM
wicked2407
Oct 30, 2006 04:12 PM
bigjermgtp
Aug 19, 2005 02:50 AM
funnycat
May 13, 2004 05:11 PM
