Turbo or supercharger
Old Jun 21, 2005 | 09:02 PM
vinceaton's Avatar
Default Turbo or supercharger
Can someone please tell me where i can find a turbocharger or supercharger for my 2003 Eclipse GTS? I've looked everywhere but the right place?!
Please help!!
Vince Eaton
Old Jun 25, 2005 | 05:28 PM
xxxkcxxx's Avatar
Default RE: Turbo or supercharger
did u try Andy's..?
Old Jul 7, 2005 | 01:22 PM
vinceaton's Avatar
Default Andy's??
I've never heard of andy's. Do they have a web site?
Vince Eaton
Old Aug 9, 2005 | 01:57 PM
BiGBoY1822's Avatar
Default RE: Andy's??
andysautosport.com, also try gofastdepot.com good luck!
Old Aug 9, 2005 | 02:44 PM
Patrick's Avatar
Administrator
if you want a supercharger for a 6G72, check with RippMods. they have some Killer 3.0s, but I have had problems getting ahold of them. i tried for a few weeks to get ahold of them to buy solid mounts for my car, and they never replied to my phone calls or emails...and you will pay TOP dollar..i talked to someone who has a Stratus Rt coupe, with a 6g74 intake manifold, supercharger, ecu, and header back exhaust, and he has around 10g tied up in the mods.
Old Aug 9, 2005 | 02:53 PM
Prophet's Avatar
And if your looking for a serious turbo kit. I have been hearing alot of good things about this set up...
http://www.tearstone.com/portal/inde...=com_frontpage
Old Aug 10, 2005 | 10:15 PM
vinceaton's Avatar
I checked at rippedmods, and the price for ADDING 365hp is around $4,200. About how much would it cost to beef up the rest of the car? Because i know my engine, trans., and axle would not be able to hold 585hp. with out a little modification.
Vince Eaton
2003 Eclipse GTS
Old Nov 17, 2005 | 04:00 PM
edaddik's Avatar
did you try EBay lately??
Old Nov 17, 2005 | 09:07 PM
Tearstone is the way to go.. cheap and AMAZING quality he is local to me here. But keep in mind that a GTS will require new pistons for anything more than 6PSI the GT motor is can take around 8-9PSI but the compression is diff between the 2 and it makes the GTS weaker.
Old Nov 17, 2005 | 09:12 PM
ORIGINAL: vinceaton
Vince Eaton
2003 Eclipse GTS
RIPPS stage 4 gets you over 400WHP and that only requires pistions. You will need a clutch the tranny should be fine. also LSD and motor mounts are a good idea.
all in all the stage 4 kit is like $6000 and that doesnt include a clutch LSD or motor mounts and tack on some labor if you cant do it yourself.
I know tearstone only charges like $800 or so for a turbo install(labor) which is a great price.
Honestly I think a turbo would be the way to go if you want more than 400WHP because RIPPS SDS is not as easy to make faster. with the SDS youll need a dif pulley set for more boost where as a Turbo you need a simple MBC and you can change it where you want
mokylok
36
Aug 24, 2007 04:21 PM
slvr_eclipse
Aug 28, 2006 08:42 PM
05Wishitwasanevo
May 3, 2006 11:30 AM
StealthR/T
Oct 13, 2005 05:52 AM
madmat
Jun 7, 2004 02:23 PM
