very hard to start when cold
Old May 7, 2008 | 11:00 AM
athineltlc's Avatar
Default very hard to start when cold
Mitsubishi 1.5 ECI 4G15. very very hard to start when the engine is cold but start very well when is warm or hot. many parts is changed, coolant sensor, spark plug and wires, rotor and distributor. etc,etc. I need your help....
Old May 7, 2008 | 03:07 PM
Default RE: very hard to start when cold
Do a compression test.
Old May 8, 2008 | 10:53 AM
athineltlc's Avatar
The compression test is good, all cylinder is ok. my possibility is on the throttle body and idle readjustment, or ECU, or TDC, but I don't no how test this item.
Old May 8, 2008 | 02:08 PM
dsm1990gsx's Avatar
How does the coolant look, does it miss a little when you first get it running. I am gonna bet you have a possible badhead gasket.
Old May 9, 2008 | 06:18 AM
athineltlc's Avatar
the coolant is good, no overheating, always in normal temperature.No leak for the coolant or oil. This morning my car run after 4 start, but the idle up and down, up and down.... last day, it's running after 10 start and my idle is ok. I don't no why is my problem.
Old Sep 5, 2008 | 09:51 AM
c3o5nnect's Avatar
You may want to switch to a different oil thickness... there are some made to help start engines in cold weather.
tonileila
Jun 16, 2018 12:51 PM
tonileila
Jan 1, 2015 02:29 PM
tonileila
Dec 19, 2014 06:56 AM
athineltlc
May 8, 2008 12:16 PM
SaraEclipse19
1st Generation
13
Oct 12, 2005 08:29 PM
