Very hard to start
Old Dec 18, 2014 | 07:43 AM
tonileila's Avatar
Angry Very hard to start
Hi all montero! I have 2003 montero limited 3.8L.It very hard to starts may be one minute for key rotation then starts if I give gas.When engine started the idling is very good and no fluctuation.
I did so far:
-new temperature sensor(every 2)
-new battery
-new starter
-new generator
-new fuel pump
-new fuel pump filter
-new fuel regulator
-new PVC valve
-new spark plug(6)
-injector clean(check fine every 6)
-fuel system pressure: 0 bar when ignition on
-fuel system pressure: 3.2bar (when engine works)
-throttle clean
-Mass Air Flow Sensor(MAF) clean
-EGR valve clean
-engine pass with scaner(Autel MaxiDiag Elite MD802)
-I put over the first fuel pump relay to the second fuel pump relay's space, than I put the second relay to the first relay's space. The car does the same as before.
HELP! What more can I do? Sorry for my small English language knowledge.
I'm waiting for answers and thank you forward.
My Email:seksarithy@gmail.com
Old Dec 18, 2014 | 12:02 PM
Akzle's Avatar
cranking for 1 minute is BAD.
I would look closer at the fuel pumps.
And check for spark at the plugs.
Reset the computer.
Old Dec 18, 2014 | 01:35 PM
tonileila's Avatar
New fuel pump(denso)
how to reset computer?
Old Jan 1, 2015 | 12:24 PM
7-UP BILL's Avatar
A bad or going bad cam position sensor will also cause a hard/no start issue. You generally will get a MIL light for this though.
Old Jan 1, 2015 | 02:29 PM
Did the fuel pump fix the problem? To reset computer disconnect battery cable and leave if off for 15-20 min. That should do it.
tonileila
Jun 16, 2018 12:51 PM
tonileila
Dec 19, 2014 06:56 AM
armymen
Apr 20, 2012 11:39 AM
athineltlc
Sep 5, 2008 09:51 AM
athineltlc
May 8, 2008 12:16 PM
