Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
3.5L misfire solved
Old May 16, 2023 | 11:13 AM
Clutch492's Avatar
Default 3.5L misfire solved
Found the problem that was causing the cylinder 5 misfire. A valve lash adjuster had fallen apart. This is located in the rocker arm. Battled this misfire for a month. Spark plugs, wires, injectors, fuel pump, mass air-flow sensor, had the ECM checked. Was still misfiring. Compression test was 150 psi. Was baffled. Upon starting the car, there would be no misfire. THEN SUDDENLY, it would start missing. Code was cylinder 5. Finally found this lash adjuster.
Erich Zeppelin
Apr 1, 2016 03:27 PM
montylimited
20
Feb 26, 2015 09:18 AM
jaystihl
Mar 27, 2014 01:16 AM
jay964
May 2, 2013 05:57 PM
Cobra
Apr 28, 2011 02:23 AM
