Cold Air Intake good or bad???
RE: Cold Air Intake good or bad???
Cold Air Intake is good except when it rains. if you hit a deep enough puddle you will suck in water and damage your engine. if it doesnt rain much where your from them go for the cold air. oh cold air is great in the winter time.
I went the Short Ram air route.
Does'nt go as low so you don't worry about water,and still makes a decent power gain of about 4-7hp.
As for mpg, i've seen a couple miles difference for the better.
you dont have to worry bout water with a cold air either....becouse most of the time the heat from the motor will evaporate the water before it can do anything...now if you plan on driven in some flood wheather you are gonna have some problems.
