Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
EGR block off
Old Dec 5, 2006 | 12:59 AM
N/Teclipse's Avatar
Default EGR block off
I have my EGR blocked off, and I was wondering if anyone knew of a way to get the check engine light off. I know a couple of people have done it on this site and was wondering if they just delt with it or knew of a way to get the CEL off. Hey slow420a if you log on anytime what did you do.
Old Dec 5, 2006 | 12:14 PM
Default RE: EGR block off
well it really depends on what type of ECU you have in the car. Because if you have a Fed ECU then you shouldnt even get a check engine light with it. If you have a cali ecu then all you need is a resistor that you have to do a small soldering job with
Old Dec 5, 2006 | 02:00 PM
N/Teclipse's Avatar
See I have the Fed ECU I thought so thats why I am confused why it came up. I will try the resistor.
Old Dec 5, 2006 | 02:06 PM
well the resistor is what makes a cali ecu into a fed ecu. So you should be fine. Id get the code to make sure that it really is because of the egr blockoff. Or make sure that you did everything correctly
dorian7
Jan 22, 2008 06:09 PM
bud660r
Jan 10, 2007 09:11 PM
ttenn
Jun 10, 2006 01:45 AM
92_laser
Nov 10, 2005 06:47 PM
mitsu4x4nuts
Oct 16, 2005 04:08 PM
