Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
help please
Old Oct 3, 2007 | 01:23 PM
1ViciousGSX's Avatar
Default RE: help please
Take the intake pipe off the turbo and check for excessive shaft play, oil leaking and rubbing between the comp wheel and the housing. Also remove the oil drain line from the pan, crank it up and see if oil drains out of the turbo, might have a restricted orifice.
Old Oct 8, 2007 | 02:22 AM
CDub's Avatar
Did you do any work right before this noise started? It sounds like an intake leak. Any loose clamps or holes on the intake side? Start with the simple stuff
Old Oct 9, 2007 | 10:47 AM
RCJr9186's Avatar
i want to make sure this isn't just typical turbo spool whistle.... does it sound like a whilstle? adding an aftermarket intake will allow you to hear the turbo and BOV mucccchhhhh louder.
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
westentertainer
Nov 8, 2014 12:47 PM
lgibson
Mar 12, 2009 07:04 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
