Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
smoke from exhaust
Old May 27, 2009 | 02:40 AM
paparoach's Avatar
Default smoke from exhaust
Why would a 1994 Mitsubishi Galant ES let out smoke from exhaust when you step on the gas?
_________________
auto body parts + Tear Drops On My Car - Jake Erkens
Old May 27, 2009 | 06:23 AM
what color smoke. Most likely burning oil
Old May 27, 2009 | 03:51 PM
BrokeDad's Avatar
If it's oil it will be more noticeable when first accelerating. It's probably a weak piston ring, valve, or something letting oil into a cylinder. Drain the oil and put in a full synthetic oil like Syntec (Yeah it's not cheap oil). If the smoking stops or drops significantly then it's an oil problem as a full synthetic won't produce hardly any smoke when burned. It's a cheap way to find or eliminate a that possibility.
Old May 27, 2009 | 09:10 PM
dsm1990gsx's Avatar
Blue smoke is oil, white is coolant, and black is fuel.
Old Jun 14, 2009 | 06:01 AM
ahlburuto's Avatar
Hi new here, I have a mitsubishi lancer 93 model. Same problem with my car. It produces white smoke. But I can't hardly distinguish if white or blue. But sometimes it produces lot of smoke, sometimes no smoke at all. What could be the first step to do? I had a change oil I think this February or march with a semi synthetic oil. Any tips?
BR
Old Jun 14, 2009 | 07:03 PM
Blck3G's Avatar
BR
Get a long stick while car is in park...Press the Crap out of the accelerator and it will show...If not that then do a Load test-Basically just drive up a hill and accelerate rapidly.
Old Jun 14, 2009 | 09:02 PM
dsm1990gsx's Avatar
BR
I personally would do a compression test, also check your oil and coolant levels too.
Old Jun 16, 2009 | 11:27 AM
BEAT's Avatar
I bet there is no oil
slvr_eclipse
Jul 26, 2006 08:47 PM
BrunoBoy650
May 31, 2006 07:39 PM
jap901
Jul 24, 2005 10:05 PM
Antwan3000
Dec 7, 2004 08:53 PM
GPR1
Mar 14, 2004 10:31 PM
