2002 lancer es
ANY HELP FOR A 2002 MITSUBISHI LANCER/ INTERIOR LEAK LOOKS LIKE COMING FROM THE PASSENGER SIDE FRONT AND REAR. ANY IDEAS? UNABLE TO FIGURE OUT WHERE THE LEAK/LEAKS ARE COMING FROM. PLS EMAIL AT CKING@NEXTEL.BLACKBERRY.NET
PLEASE STOP YELLING ! (That's what all caps is!)
Anyway. We need more info.
What is leaking in? Water? Engine Coolant?
Does it only leak when it rains?
Does it only leak when you run your A/C?
Do you have a sunroof?
Have you had a windshield replaced recently?
Here are some common Consumer Reports items:
Water leak: Water leaks onto the front floor due to debris (leaves, etc.) clogging the drain tube in the blower motor housing requiring a filter to keep stuff out. (2002-03)
Water leak: Water may also enter past the wiper arm pivots damaging the blower motor and requiring special caps to be installed over the pivots. (2002-03)
Water leak: Water may also enter the car via the rocker panels (side seals) or the area around the upper dash requiring resealing. (2002-03)
milwaukeelancer
Oct 18, 2005 07:18 PM
ignaciodelforn
Feb 19, 2005 12:26 PM
