Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
2002 lancer es
Old Feb 2, 2006 | 06:22 PM
kingman4309's Avatar
Default 2002 lancer es
ANY HELP FOR A 2002 MITSUBISHI LANCER/ INTERIOR LEAK LOOKS LIKE COMING FROM THE PASSENGER SIDE FRONT AND REAR. ANY IDEAS? UNABLE TO FIGURE OUT WHERE THE LEAK/LEAKS ARE COMING FROM. PLS EMAIL AT CKING@NEXTEL.BLACKBERRY.NET
Old Feb 21, 2006 | 04:43 PM
mharrison's Avatar
Default RE: 2002 lancer es
PLEASE STOP YELLING ! (That's what all caps is!)
Anyway. We need more info.
What is leaking in? Water? Engine Coolant?
Does it only leak when it rains?
Does it only leak when you run your A/C?
Do you have a sunroof?
Have you had a windshield replaced recently?
Here are some common Consumer Reports items:
Water leak: Water leaks onto the front floor due to debris (leaves, etc.) clogging the drain tube in the blower motor housing requiring a filter to keep stuff out. (2002-03)
Water leak: Water may also enter past the wiper arm pivots damaging the blower motor and requiring special caps to be installed over the pivots. (2002-03)
Water leak: Water may also enter the car via the rocker panels (side seals) or the area around the upper dash requiring resealing. (2002-03)
Old Feb 21, 2006 | 06:16 PM
slow420a's Avatar
sounds like a bad weather seal.
Old Jun 13, 2006 | 07:03 PM
lancerOZ's Avatar
my thoughts exactly
ORIGINAL: slow420a
woosqrd
May 10, 2006 12:31 PM
Nicolelizabeth1
Oct 28, 2005 09:50 PM
milwaukeelancer
Oct 18, 2005 07:18 PM
ruslancer
Mar 5, 2005 02:59 PM
ignaciodelforn
Feb 19, 2005 12:26 PM
