02 Mirage radio wires-HELP!
Old Aug 13, 2008 | 11:37 AM
christyaq's Avatar
Default 02 Mirage radio wires-HELP!
I have a 2002 Mirage and I was putting an aftermarket headunit in.. I know you are not suppose to cut the wires to the factory harness, but I couldn't find an adapter anywhere. So I cut!(STUPID ***!!) I had 2 xtra wires after connecting the colors that matched together and this blew the fuse. I had a hell of a time trying to figure out what happened to my lights inside. So I tried to connect the factory harness back together (finally found an adapter) Now my front left, rear right speaker are not working and everytime I hit a bump the stereo stops playing. Is there anyone that has the wiring diagrahm, or color codes? I would really appreciate this. I have looked everywhere and can't seem to find them. Thanks everyone
Old Aug 13, 2008 | 03:00 PM
Lil Evo's Avatar
Default RE: 02 Mirage radio wires-HELP!
http://www.mirageforums.net/viewtopic.php?t=32105
I did a write up on another forum, this should have all the information that you need. Be sure that all your connections are solid. If it goes out when you hit a bump, it's more than likely a bad ground. There's a steel support running behind and to either side of the radio cavity. Get yourself a self tapping screw and a star washer and use that for a ground. Let me know if there's anything else you need.
Chris
Old Aug 13, 2008 | 03:31 PM
Kaede.Noir's Avatar
^x2 about the bad ground
Evo.. seriously.. my respect... you know your stuff
Old Aug 23, 2008 | 10:48 PM
Lil Evo's Avatar
Thanks dude
Old Aug 24, 2008 | 03:26 PM
christyaq's Avatar
Thanks for the info! going to try today. I'll let you know if I F*** anything up or have any questions! LOL
lekamikaze
Dec 4, 2007 04:04 AM
yuvex107
Dec 1, 2007 08:14 PM
lekamikaze
Oct 2, 2007 09:22 AM
mirage_1313
Oct 30, 2006 09:47 PM
Lowdown
Oct 10, 2005 05:59 PM
