98 Spyder All Lights Flicker/Flash with Turn signal's ON
Old Nov 10, 2008 | 07:41 PM
tyson724's Avatar
Default 98 Spyder All Lights Flicker/Flash with Turn signal's ON
I just purchased a 1998 Mits Eclipse GS Spyder and noticed that the headlight, dashlights,taillights Flicker when i turn on Turn Signals .
Why ? Is there a Fix ?
Old Nov 10, 2008 | 07:54 PM
dsm1990gsx's Avatar
Default RE: 98 Spyder All Lights Flicker/Flash with Turn signal's ON
Check the charging system voltage, the alternator might be taking a crap.
Old Nov 12, 2008 | 08:51 PM
Lil Evo's Avatar
^^^^what he said. your alternator should be putting out a minimum of 13.9v DC with the vehicle running at about 2k rpm. Also, take the car to Auto Zone, NAPA, Advanced, or another store that does free battery tests and make sure that the battery isn't going out.
Old Nov 14, 2008 | 06:00 PM
tyson724's Avatar
I took Ground Wires Off Body and Sanded to bear metal . Problem is now gone .
MrGalantGuy
Nov 18, 2014 12:53 PM
claytonkobe
Sep 19, 2010 12:28 PM
klas
Jan 23, 2009 03:52 PM
capecodder
Aug 4, 2007 08:32 PM
dornstar
May 22, 2006 04:58 PM
