can this be done! straight swap the factory 10" sub with aftermarket 10" subwoofer .
Old Aug 7, 2013 | 06:20 PM
RVR's Avatar
RVR
Default can this be done! straight swap the factory 10" sub with aftermarket 10" subwoofer .
Hello. I need some input in this matter. I own a 2013 Mitsubishi RVR and this is what I would like to do the factory sound system. I want to straight swap my factory 10" Rockford fosgate subwoofer to 10" W7 subwoofer. Can this be done and also can the amp also be swapped and does any one know where the factory amp is located for the 2013 Mitsubishi rvr. I don't want to cut no wires or add anything else that would make this very complicated . Is it possible. thanks for any input in advance.
Old Sep 26, 2013 | 11:06 AM
Vadimus's Avatar
You need to swap lots of stuff as stock Rockford amp is CAN-controlled one.
Old Oct 1, 2013 | 10:26 AM
djet38's Avatar
anyone know which color wires run to the sub from the amp? I'm trying to hook up LED's to pulse with the bass
jsevinsk
Aug 14, 2022 10:36 AM
Serv_466
May 20, 2011 08:17 AM
treasguy
Jan 28, 2010 07:15 PM
