Drilling a hole in firewall
Old Mar 7, 2009 | 10:50 PM
D. Yoda's Avatar
Default Drilling a hole in firewall
Ok, I'm trying to install an amp and I've gotten everything done great til I got to running the power wire...I thought it would be easy but I can't seem to find a hole in the firewall...I've been told that if I can't find one I need to drill one...So could anyone recommend where I should drill the hole?...
Old Mar 9, 2009 | 08:08 AM
There has to be a hole because of other wires that run though. But usually it has a rubber grommet and is full of wires. But i ran my power wire along the door step and then up around the 1/4 panel. I think most people do this. But if your intent on drilling a hole your gonna need a good drill bit and basically you have to just get under there and try and find a place that you feel is safe.
umek
Aug 4, 2013 02:46 AM
josh1988
11
May 7, 2007 02:59 PM
josh1988
May 7, 2007 07:57 AM
jimbo_limited
Mar 15, 2006 09:21 PM
1998blackgst 240
Apr 12, 2005 05:49 PM
