Galant'98 parking lights
(from the12volt.com)
1998 Mitsubishi Galant Security Information
Constant 12V+
Red
Ignition Switch Harness
Starter
Black/Yellow
Ignition
Black/White
Ignition 2
Blue/Black
Accessory
Blue/White
Tach
White
In Black Connector at Distributor
Brake Switch
Green
Brake Switch
Trunk Pin
Green/Black (-)
Trunk Light
Parking Lights
Green/White (+)
Gray Connector left of Steering Column
Head Lamp
Red/Yellow (-)
Light Switch
Factory Disarm
Yellow/White (-)
Driver's Kick Panel
Door Trigger
Green/Red (-)
Above Fuse Panel
Door Lock
Green/White (-)
Blue Connector left of Steering Column
Door Unlock
Red/Green (-)
Brown Connector left of Steering Column
Horn Wire
Green/Red (-)
Steering Column
Windows Up
LF=Red/Blue, RF=Red/Blue, RR=Red/Black, LR=Red/Black
Windows Down
LF=Green/Black, RF=Green/Black, RR=Green/Black, LR=Green/Black
1998 Mitsubishi Galant Stereo Information
Constant 12V+
Red/Black
Switched 12V+
Blue
Ground
Chassis
Illumination
Green/White
Dimmer
Black/Yellow
Antenna
Left Rear
Front Speakers
5 1/4"Doors
Left Front (+)
White/Blue
Left Front (-)
Black/Blue
Right Front (+)
White/Red
Right Front (-)
Black/Red
Rear Speakers
6" x 9"Rear Deck
Left Rear (+)
Yellow/Blue
Left Rear (-)
Gray/Blue
Right Rear (+)
Yellow/Red
Right Rear (-)
Gray/Red
1998 Mitsubishi Galant Cruise Control Information
Constant 12V+
Red
Ignition Switch Harnessor Use Hot Side of Brake
Switched 12V+
Black/White
Ground
Use Chassis
Near Cruise Control Module
Hot Side of Brake
n/a
Brake Switch
Cold Side of Brake
Green
Brake Switch
Tach
White
VSS Wire
Yellow/White
Passenger's Side of Console 26 Pin Connector POS19
Pulses Per Mile
4000 PPM
Notes: Vehicles with Manual Transmission require Clutch Switch.Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.i think that should clarify things
Constant 12V+
Red
Starter
Black/Yellow
Ignition
Black/White
Ignition 2
Blue/Black
Accessory
Blue/White
Tach
White
Brake Switch
Green
Brake Switch
Trunk Pin
Green/Black (-)
Trunk Light
Parking Lights
Green/White (+)
Head Lamp
Red/Yellow (-)
Light Switch
Factory Disarm
Yellow/White (-)
Driver's Kick Panel
Door Trigger
Green/Red (-)
Above Fuse Panel
Door Lock
Green/White (-)
Door Unlock
Red/Green (-)
Horn Wire
Green/Red (-)
Steering Column
Windows Up
Windows Down
Constant 12V+
Red/Black
Switched 12V+
Blue
Ground
Chassis
Illumination
Green/White
Dimmer
Black/Yellow
Antenna
Left Rear
Front Speakers
5 1/4"Doors
Left Front (+)
White/Blue
Left Front (-)
Black/Blue
Right Front (+)
White/Red
Right Front (-)
Black/Red
Rear Speakers
6" x 9"Rear Deck
Left Rear (+)
Yellow/Blue
Left Rear (-)
Gray/Blue
Right Rear (+)
Yellow/Red
Right Rear (-)
Gray/Red
Constant 12V+
Red
Switched 12V+
Black/White
Ground
Use Chassis
Hot Side of Brake
n/a
Brake Switch
Cold Side of Brake
Green
Brake Switch
Tach
White
VSS Wire
Yellow/White
Pulses Per Mile
4000 PPM
Coops217
Dec 30, 2016 11:03 PM
missyjeff2000sport
Apr 5, 2005 09:04 PM
