MMCS Aux wiring with TV box
Old Aug 18, 2015 | 12:34 AM
geeveejay's Avatar
Default MMCS Aux wiring with TV box
I have been reading quite a few threads relating to this but non cover my issue.
I have recently bought a 2008 Japanese V6 Outlander with MMCS 03. In Japan it was fitted with a factory TV option. I am in NZ and this will not work here so can come out ( Unit part no is TU200D).
I am trying to get Aux working for Ipod. The local experts here say the issue is with this box. Pressing Aux just gets a Japanese error message Disconnecting the TV box does allow the Aux to take you to the Aux page and gets rid of the error. I have traced the RCA plugs at the rear of the centre console back to under the passenger seat and they are just extension cables that run into a loom. There are RCA females at one end that join into a short loom to a large black square multi plug that goes into a socket marked I/O bus on the TV box.
I suspect they just piggy back off the multi pin plug . My thoughts would be that to get it to work it would be a case of connecting some of these pins together to get the signal from the RCA sockets. Can anyone help with the wiring diagram or experience
I can then connect the Ipod to the female RCA plugs via a jack plug.
The other option I have looked at is using the 8 pin mini din to 30 pin Ipod cable. There is a socket for this in the back of my MMCS. Cable has not arrived yet so I have no idea if this will work yet
Old Sep 23, 2017 | 02:29 PM
benomobile's Avatar
Hi, I know its been a while, but did the 8pin to 30 pin ipod cable worked in the end?
Thanks
Ben
Doublecheese
40
Jul 27, 2020 07:57 AM
Eclipse440
Jul 14, 2015 11:08 PM
Otaku
Feb 13, 2014 04:59 AM
Mpit52
Aug 19, 2007 02:07 PM
budh
May 28, 2007 10:14 AM
