Noob electric gauge question
Old Feb 20, 2008 | 05:28 PM
firebuck's Avatar
Default Noob electric gauge question
I ahve a 2003 eclipse gt. I am going to add 3 gauges and I am wondering where I should connect electrically. Should I get some fuse taps and tap the fuses in the side panel on the dash? or should I run a new wire from the battery to the a-pillar? If I do tap the fuses shoul it be 1 tap fuse per gauge? The gauges are voltmeter, oil pressure and temp.
Any help or link swould be appreciated.
Old Feb 21, 2008 | 02:45 PM
Lil Evo's Avatar
Default RE: Noob electric gauge question
if you have to ask if whether or not you should run a 12v constant wire to your guages, I recomend taking it to a professional.
Old Feb 23, 2008 | 08:26 PM
firebuck's Avatar
I'm sorry I wasn't clear. It wasn't a constant run from the battery but a new line to a switched fuse block located under the dash. I was just wondering if tapping the fuse box for 3 gauges is a good idea or if a separate run is required.
Old Feb 24, 2008 | 01:44 PM
Lil Evo's Avatar
if it were me, i'd just go straight to the ignition harness for your ignition/ACC wire (whatever it is the guage says to tap into). I try to stay away from the fuse box if at all possible, it just makes for a cleaner looking install.
Old Feb 24, 2008 | 11:05 PM
lhausi2's Avatar
yeah lil evo's right usually you tap into the ignition wires, which is why when you turn the key the gauges come on
Old Feb 24, 2008 | 11:06 PM
lhausi2's Avatar
and trying to wire into the fusebox is gunna give you more headaches then you need
burnmyeyes
Jan 2, 2008 09:04 PM
2001EclipseGTnub
Jan 18, 2006 03:36 AM
3000gtkid1119
Dec 2, 2005 03:50 AM
egb18c
Mar 15, 2005 01:13 AM
