Power Window Issue!!
I need some major help from you guys. My friend and I were installed a sub and amp in my 2007 eclipse. When we finished the installation I tried to roll up the drivers side window and it would not roll up all the way. It only rolls up a quarter of the way and stops. We checked all the fuses, including the fuses for the power windows. The passenger window rolls up fine. Any help will do. If you guys could tell me where I could get the wiring schematics for the 4th generation eclipse that would be awesome. I really need to get this to work because it is my only means of transportation. Thanks a lot for your time and help!
If the window rolls up and then stops, I would imagine the electrical part is good. Pull the door panel off and see if the regulator is getting jammed up or could be a window motor crapping out.
GAMitsuBoy
Dec 17, 2017 08:25 AM
3000gt1999
Jan 11, 2007 09:12 PM
