Power Window Issue!!
Old Mar 16, 2008 | 02:40 PM
thebutcherr's Avatar
Default Power Window Issue!!
I need some major help from you guys. My friend and I were installed a sub and amp in my 2007 eclipse. When we finished the installation I tried to roll up the drivers side window and it would not roll up all the way. It only rolls up a quarter of the way and stops. We checked all the fuses, including the fuses for the power windows. The passenger window rolls up fine. Any help will do. If you guys could tell me where I could get the wiring schematics for the 4th generation eclipse that would be awesome. I really need to get this to work because it is my only means of transportation. Thanks a lot for your time and help!
Old Mar 21, 2008 | 08:59 AM
dsm1990gsx's Avatar
Default RE: Power Window Issue!!
If the window rolls up and then stops, I would imagine the electrical part is good. Pull the door panel off and see if the regulator is getting jammed up or could be a window motor crapping out.
Old Mar 21, 2008 | 02:42 PM
blk n tan's Avatar
also check the window run channel. if its bound up or causing any kind of resistance that motor will just give up trying to lift it. that is not at all an electrical issue however
GAMitsuBoy
Dec 17, 2017 08:25 AM
E3000
Aug 28, 2009 08:03 AM
thebutcherr
Mar 16, 2008 03:33 PM
Mitsufahrer
Oct 29, 2007 12:40 PM
3000gt1999
Jan 11, 2007 09:12 PM
