Wiring help needed...
Old Aug 23, 2007 | 07:59 PM
Jaypesta's Avatar
Default Wiring help needed...
[:@]okay here's the deal, i have a 2000 Eclipse GS &i had my pioneer radio in my car, to make a long story short -the face plate shorted out and now my needle lights don't work, i took my gauge clusterout and found that the three main lights that light up the needles were burned out, (keep in mind all myother lights work ie; turn signal indicators, seat belt indicator, bright light indicator, brake indicator - every thing else works)i replaced the bulbs and tried again, still ano-go on the needlelights.and also the lights inside my AC/Heater control cluster and the light that is in the consol in front of the gear shift are also not working... this leads me to believe that they are all on the same circuit...My fuses are fine, i have checked them several times.
originally i had my radio wired through the wiring harness's ground wire...but for some reason , now when i use that wire (instead of grounding out through a metal part of the chassis) the radio turns off when i turn on my head lights...i have obviously shorted some thing out, but i have no idea where to start looking orwhat to do...can some one help me or point me in the right direction as to where to start....it really sucks not being able to see how fast im going at night
thanks in advance
Old Aug 23, 2007 | 08:50 PM
RedGalant2k1's Avatar
Default RE: Wiring help needed...
Sounds like you shorted out a relay fuse. What kind of and year car do you have?
Old Aug 23, 2007 | 09:13 PM
Jaypesta's Avatar
sorry i for got to put that in there...its a 2000 eclipse GS
Old Oct 10, 2007 | 09:19 PM
DaPcManaic's Avatar
I actually have a similar problem with my car now. Not exactly the same.
95 Galant.
I got in my car one day and my dashboard lights stoped working. Turn signal and 'check engine' lights were fine. The instrument panel with my radio and Ac lights also dont work. Although the radio and AC do work.
Finally i noticed that my tail lights also dont work anymore.
The wierd thing is, I noticed that when i brake, sometimes the instrument panel/dashboard lights up, sometimes it dont. It always goes away when i let go of the brakes however.
Can anyone help? Ill be bluntly honest and admit my inadequacy with cars up front.
Old Oct 10, 2007 | 10:37 PM
Kaede.Noir's Avatar
First of all... details, why not grounding it to chassis? what wire did you say you tap it into? are you not tapping it somewhere else, something cluster related?
Old Oct 11, 2007 | 09:30 AM
Lil Evo's Avatar
rip it all out and start from scratch.
Old Oct 12, 2007 | 05:55 PM
Jaypesta's Avatar
well guys after a few weeks of trying to fix this particular problem , i finally did it...and all that caused my lights to not work was a short in my dimmer switch...i have since fixed my dimmer switch and have gotten all my liughts to work again, so thanks for all your help ppl, and good luck with any future projects...[/align][/align]
djet38
Oct 2, 2013 08:17 AM
BruceWayne
Apr 8, 2010 10:48 AM
anthony_piaa
May 21, 2007 04:11 PM
bluballz07
Oct 4, 2006 07:48 PM
