Convertable top motor not working
Old Aug 19, 2007 | 04:55 PM
l5gt's Avatar
Default Convertable top motor not working
This is my 1st post.
My convertable top on my 1996 Mitsu Spyder GST has ceased to function, when I push the button I don't hear the whirr of the motor, but I do hear a faint click coming from what I imagine must be a relay (large box with 3 large wire connectors situated behind the backseat- middle).
Do you think this is the problem and the relay box needs to be replaced?
OR what should my next step be?
Thanks......
Josh
Old Aug 29, 2007 | 10:07 PM
98gstspy's Avatar
Default RE: Convertable top motor not working
i would take a look at the wires going to the motor and the motor because the problem is most likely in that area. mine did that once or twice a while back. turns out the ware had a cut in it so it wouldnt work it it hit the rear bars. so a little electric tape will fix that if its your problem. if you can find that derectly hook up a power source to the motor and c if it works.
Old Oct 24, 2007 | 07:15 PM
dsm1990gsx's Avatar
Check to see if you have power at the motor.
Old Oct 24, 2007 | 09:26 PM
Lil Evo's Avatar
take a meter to it, you should see a 12v constant, switched power and ground if I'm not mistaken. if one of those is not present, there be your problem
metalmilitia
May 10, 2008 02:17 PM
DaShot19
Sep 24, 2004 11:08 AM
DaShot19
Sep 9, 2004 07:20 PM
snoop
Jul 6, 2004 07:41 PM
habeeb341
Jun 4, 2004 10:47 AM
