3000GT trouble
hello i recently bought a 95 3000GT with 132000 miles on it
i drove it to the gas station one day last week and the afer i filled the power steering belt broke and made my timing skip a few notches the car car died out and would not start again...
what should i do?
what should i do?
Put the timing belt back in time, and try to start it.
Thats pretty much the only way to tell if the motor is okay. You could tear it down if you wanted, but that is a little more costly.
Good luck!
Good luck!
95 3000Gt DOHC
At this point I know the I now know the engine is out of time. I has aligned the cam marks to their appropriate position. The crank timing mark is at 6:00 (Straight down). This would be about 130 degrees. Is it a given that the valves have bashed the pistions? RPM was low at the time. Is this engine a 0 clearance engine or and interference situation
